Apparently AOL is teaming up with a company called "Cellufun" to create an ad-supported community mobile gaming channel. Sounds interesting.
Apparently, the games will be tested popular titles that have proven themselves on mobile phones already.
Take a look at http://wap.aol.com/games where you can currently play mobile games courtesy of AOL. Eh... after seeing Duke Nukem on an Android Phone I'm not sure how excited this makes me.
How did you add that dolby addition anyway?i cant believe how nice the dolby addition to the stock music player sounds. i ditched poweramp for it. i must admit im very impressed with how well it sounds.
what u guys think?
It's the third button from the left when you fully open up the app and view the song currently playing. It's usually disabled unless you have external speakers plugged in, and yes, it is quite amazing.How did you add that dolby addition anyway?![]()
Here's the button to turn on Dolby
Ive flashed beat audio for my samsung Admire threw CWM, Will I be able to use it on the Connect?
That beats.zip is bull there was a thread on this in the esteem forum and it turned out to be fake.
Oh and none of these eqs are engineered for a device. It's just a sound enhancer that the audio is processed through.
But Dolby does sound awesome![]()
if you put dolby on the esteem it wouldnt sound the same as it does on the connect
it is definitely engineered in sync with the hardware and the kernel
if its just a software thing dolby would sell it as an app
its been ported systemwide to plenty of devicesi doubt it would have the same effect
Youre right it'd have better effects since it would be system wide and also have both a mode for headphones and speaker. If you know what you are doing (not saying I can port this) Dolby can be integrated into a devices Rom. These things aren't sent to Dolby so they can build an entire sound enhancer for just one device. Instead manufacturers use Dolby code and integrate it into their devices. The world doesn't revolve around the connect
And it is absolutely in every shape and form a software thing, same goes for beats. There's no magic Dr. Dre chip inside that drops the beat with exta pizzaz.
until then i will have to continue to believe it is specificalky engineered for optimal performance on specific audio hardware whether it b esteem connect or beats phonesi think we shud just agree to disagree unless u can bring me solid factsuntil then i will have to continue to believe it is specificalky engineered for optimal performance on specific audio hardware whether it b esteem connect or beats phones
http://www.androidauthority.com/beats-audio-htc-one-series-details-59939/
Not the best article but it gets the point across. If beats isn't only software then why can I flash sensation xe roms onto my original HTC sensation 4g with absolutely no modification? HTC released the xe months after the original sensation. All it was, was a 300mhZ overclock, red accents, larger battery, and beats audio. These 2 phones are identical internally yet only one is supposed to have beats.
I'll look into Dolby and find more info on beats later![]()
Any of you guys up for trying the Dolby apk I pulled![]()
trying it on what?
its a lib and a system apk, you can try it just make a nandroid. If it doesn't work then just do a restore
