I know I did serch how can I delete some of my bookmarks in Dolphin HD, thanks.
Just a side note for idiots like me... after you long press on the bookmark you want to delete, and it brings up the list of actions, you have to scroll to the bottom to see the delete options. It didn't look like their were other options to me, so I tried this a dozen times before realizing I needed to scroll.
Using Dophin HD, is there a way to put shortcuts to bookmarks directly on a home screen? With the stock browser, I can do this, and put up to 16 bookmarks on 1 home page. With Dolphin HD, all I've found is a widget that puts 6 bookmarks on a page.
I found I can place a Dolphin Bookmark link to a page on my home screen, not found the widget though. Press and hold on an empty space on the home screen, select shortcut, select Dolphin Bookmark. that will open a page for you to choose the bookmark you want.
With this method I could get a total of 16 bookmark shortcuts on a clear home screen page... would be nice to be able to add the links inside a folder on the screen.
I was able to put the bookmarks in a folder. Just create the folder and drag the icon to the folder.
