luvduchovny
Member
Yep, I'm a wooter who got a G-Tab in the mail the other day. I was going to root it but decided to just use it in the state it's in until I get bored ... then I'll root it.
So the question is... I installed newer versions of the Facebook app and the YouTube app because the original on the tablet both those programs would crash. Installing the newer versions fixed that problem but now under Applications I have 2 Facebook and 2 YouTube apps. If I go the standard route of Manage Applications, it only has the new apps as the ones I can uninstall. I know these old ones are in the Master Apps folder. Any way to get rid of the old apps? Would replacing them with the newer apps in that Master folder do anything?
This should probably be in troubleshooting section. Sorry. Maybe a Moderator could move this?
