contradictions
Member
I bought my captivate on launch day, filled with all sorts of excitement for a good Android phone on AT&T. It was good for a while, until I got hit with the GPS bug, and then the lag. My GPS started working much better after one of the updates, but the lag was a problem that just kept getting worse. I missed calls because the phone wouldn't respond when I tried to slide to answer. It would take 20+ minutes to power on the phone, and generally was just completely unreliable. I tried doing a factory reset, and it just didn't make any difference. My phone was just mostly useless. Finally I had a wifi problem that I just couldn't get working, so I took it to an AT&T repair center. I got a replacement phone, put my apps back on, and I have a working phone again. I can power on the phone and get back up and fully running in about a minute.
Sure, it's not Froyo, and it's not a custom rom. But, if you have a Captivate that doesn't work the way it should. Don't hesitate to do something about it. Even on Android 2.1 this phone should be a very good phone for most of you.
