Root Double Lock Screens
LittleRedDot
I'm using a custom screen locker from Go Locker, but everytime I reboot I have to go through the sense locker, then the Go locker, then the pattern lock.
How do I disable the sense loscker in mik 3.0?
That unfortunately is a glitch with go locker. I tried it a while back and deleted it because of that reason. :(
I don't think its possible to remove the lockscreen. I could be wrong though.
Let me do a little research when I get on my pc, or hopefully another member will chime in if I'm wrong. :)
I'm usi
What happens is, go locker and launcher are both apps and take time to load after rebooting. Think of it like a computer and how the programs take a few to load. Your stock locker is the default locker and your stock launcher is your default launcher and they will load before your secondary apps. wear I've learned from rooting and flashing my phone is you have to learn patience. I hope this helps.
I've had this problem with WidgetLocker too in the passed. Didn't happen everytime, but more often than not so i stopped using it.
go to settings
go to display
scroll up to screen proximity saftey
turn off proximity sensor
problem solved
thank you to my brilliant daughter:D
