Root double notification and ringtone
tlopez1973
hey did any one get double notification and ringtone when flashing new reload cm7 1-21-12 build. now is there a way to erase a folder to get rid of extra notification and ringtone.i check in system media folder and it does not show doubles in there
no i dont get this... do you have a 3rd party messaging app? cause you may have them both set to go off
I have the actual ringtones and notifications in my phone doubled
mt-triumph-cm7
mt-triumph-cm7
do you have two places for your ringtones? ex. "ringtones" folder on root of sd card and "media>audio>ringtones" folder? if you double up they might show up twice in the ringtone selector
EDIT: is it still like that if you reflash the rom?
EDIT2: were they doubled before you installed your ice cream sandwich theme?
