Root double text....
lakai113
just the other day i did a factory reset/themed (revolution)/and added the build.prop last night..
well now i am receiving the same text message twice in a row.. i restarted the phone and did a back from the other day so that should not have the build prop on it but it is still doing the double text.. have any of you had this problem?? and is there a way to get rid of the theme othe than another factory reset??
well i did the factory restore and i still have the REVOlution theme and i am still getting the double text... WTF... no ideas??
If you have the REVOlution theme on there thats why. Use Titanium Backup to freeze one of the text messaging applications and you will be all set. I had the same problem.
Freeze is only available in donate version ($5.99). Is there any other way to do this? Thanks.
EDIT : I found it. It is listed here in full details.
http://wiki.fabdroid.com/index.php?title=Using_Scripts
Short verion:
Open Terminal Emulator
Type : su
Type : messaging
It will output -aosp and -mot
Type messaging -aosp for other SMS apps or
messaging -mot for stock.
You are done!!
