Double txts
imamabella
I tried searching for this but no luck I've been getting double txts from everyone how can I stop this
this used to happen to me when i installed GO sms pro, but now it fixed, all i did was block or free the previous messaging app.
try clearing data and cache for that messaging app.
Actually I don't hve any apps like that for SMS just stock, but I have the Go launcher but this was happening before I put that app on n I'm not rooted either
I had the same problem when I had the stock messaging app installed but it would come and go and it usually would only do it from people with Iphones. Strange. I don't know what was causing it. But once I started using GOSMS I don't get doubles at all anymore. I don't know.
Unfortunately it's nothing new to alot of people. But yesterday I did a factory reset on my phone because my launcherpro was really slowing down my phone plus I wanted to clean out my phone to run as good as it started. So once I did that, I signed it my existing information AND I'm not getting duplicate texts anymore :)
If I do a reset will I loose everything from apps to contacts
Yes. Everything will be erased. Make sure everything is backed up on your SD card. :D
BUT hopefully you already have Titanium backup and you can restore apps with the click of a single button. ;)
Also to the question I've seen several topics on rooting ur pool gone if anyone know the link. Im going to root.
I get those double texts as well sometime. I'm only using the stock mms app. Even when I do a factory reset/wipe, it still does it sometiomes. I'm on the ZVC update. I don't think I had any problems on ZVB though with the double text. I don't know It's annoying but, can deal with it! :D
i occasionally get the, but it is most always from one or two people, who use iphones. i know a couple other friends that use iphone and i do not get duplicates (tho, all out of order sometimes/a LOT, most always happens, most ESP w/iphone msgs sent to me). this has been the case with stock, GO & other msg apps. GO is the one i have/use now & like it, BUT* (& sorry to invade yer thread, i asked this a wiles back & the thread died & i am still wondering/hoping there is something i can do/or i am forgetting, to fix this)
*i cannot send a word mms, all is fine if a photo/vid is sent along, but IF only words, 160+, then it doesn't send, on stock msg OR GO,ffs:mad:
am i missing,forgetting smth simple in settings?? everything appears in order, just doesn't make sense, to me, that i can send a vid/pic mms, but not one o just characters/words.
Good Luck imamabella - hope it gets fixed, a solution is found & thanks as always for ALL helpful people on here!
Cheers!
