DoubleTwist Droid Update
Soooooooooooooooooooo
I know DoubleTwist is the Adolf Hitler of the Android music apps so far. To be honest, though, I first started using it a while ago and it worked perfectly.
Then there was an update. You can see where this is going...
Now I can't sync my Droid to DoubleTwist at all. It says it's syncing (foreverrrr) and then just stops and says sync failed. All I really want out of the program is to have playlists (preferably in alphabetical order) that I can easily arrange on my PC and then sync to my Droid.
If there's another application that does that, then that'd be great. Otherwise, I'd rather not have to click every single song in my Droid and press "add to playlist."
Anyone have any suggestions for another app? Or possibly be able to help me with DoubleTwist?
Thanks!
