Thanks for the reply. The links on that thread tell me that the files have been removed.Youi will need to download the Vodafone, Gingerbread, firmware from here and flash it to your phone using Odin.
Phone Brand: Samsung
Phone Model: GT-I9100
Build Date: 01/01/2012
Android Version: 2.3.5
Type: Branded
PDA: BUKJ3
PHONE (Modem): BUKI1
CSC: VD2KI2
File Name: GT-I9100_VD2_I9100BUKJ3_I9100VD2KI2_I9100BUKI1.7z
I did put firmware on it I found elsewhere.
This didn't work though. When booting the phone, I get pop ups telling me that apps have stopped unexpectedly. Can't get past the 'Welcome to GT-I9100 screen.
You cannot flash Gingerbread over the top of ICS without doing a Factory Reset and erasing your Internal USB storage first as you are downgrading.
Downgrading to Gingerbread has caused problems in the All Things Root section of the forum, in the past I'm afraid. In some cases the PIT files have had to be flashed to downgrade. It's not as easy as going from Gingerbread to ICS unfortunately, sometimes.
You could always flash a different ICS ROM instead.
I did a factory reset earlier (when ICS was still on it)
Still stuck.
Then I would urge caution and let Samsung or Vodafone sort you out.
Managed to get version 2.3.6 onto it. Carphone Warehouse firmware.
