Hello, I have been searching around various forums for a solution here and would like to get some expert advice.
I had a Samsung Galaxy S3 SCH-i535 with Android Version 4.3. I would like to downgrade it to 4.1.1 or 4.1.2.
From what I have read, the 4.3 update has a new bootloader and prevents you from using Odin to flash to a previous firmware. Is this correct?
Given that, isn't there some other way to install 4.1.1/4.1.2? Can't you root the device to install custom OS's? In theory then, can't you do something to revert back to the old OS?
Thank you for your help.
