Help Downloaded widgets don't load after restart
djfl
Hello.
I use "Agenda Widget" for my calendar, Google "Tasks" for my notes to self, and "Multicon" for my apps to display on my homepage nice and small. After turning my phone off and restarting it, none of these widgets will load.
I've done a search on google and this site and can't find a solution to this problem. Help?
Thanks in advance.
When you say they will not load do you mean that they disappear completely, or there is a box that is where the widget should be? Are you using the stock launcher?
