Root Downloading Sys Updates, Help
rm2092
Ok so I have my phone rooted with Unrevocked and not sure if this is the problem but to day I got the notification for a sys update from HTC so I downloaded it and went to install it. So I go to install the update, phone turns off and starts the install and then the screen goes to a yellow triangle with the little android guy there and it just sits there and does nothing so I pulled the battery to allow the phone to turn back on. After all that I still get the message to install the update is my problem because I have rooted my phone or is it something else ? Thanks
you dont wanna update your phone if your rooted!!!!
if you update your ph ota you will lose your root and i think it changes the HBOOT and i THINK you will have trb rooting again!!!
if you want some of the new updates on 3.70 update to a newer rom!
