Root Dr. Cloverdale Theme/Froyo Camera
reinert012
You wouldn't get much of that theme to work with a Sense based rom anyway. Same thing goes for the camera...the HTC one won't play too nice with a CyanogenMod based Froyo rom. Keep an eye out for KaosLegendary though as he is porting a 2.2 Sense based rom from the Wildfire. Most of it works now from what I understand. I am sure there are some more kinks to work out though as this just popped up the other day.
Found a link for an older CM Rom of his and downloaded to my dropbox for you.: http://dl.dropbox.com/u/9903887/MagicElixirROM.zip
You can use it to extract the framework-res.apk and get most of the images and icons with it and whip up a Metamorph perhaps. Keep in mind, this is CM 4.2, which is the only version I could find with an active link. There are quite a few differences between this and a Sense based rom's framework, but it's at least a jumping off point...
