keysdesease
This is a real popular app so i am thinking that others might be experiencing similar issues as i am or might have a possible fix? I use "draw something" to play with my daughters periodically. On my Esteem I had no problems, since is started with the Spirit after downloading the latest version from Google the app starts then the screen goes totally black but the soft keys on bottom are lit. If you press the center of the screen u will get a facebook login screen. Prior u would have this or a draw something account info. I have reinstalled the app copious amount of times. Found older versions and still no change. i remembered that when it first came out it was written to work with flash only and since i had flash installed on the Esteem i thought i had it figured out. Installed flash on the Spirit but still get the same response
. Last resort was to open a faceslap account, which i do not want to do, but i did and dammit after i log in using those credentials the screen goes back black again but is running in the background. This is what the developer suggested to someone on another forum, his problem was crashing tho. Oh, i did not help either.
If you're using an Android Device:
1) Force Stop the app.
-Open the Settings menu of your Android OS.
-Select Apps.
-Look for the tab that says "Running".
-Choose Draw Something and tap on Stop.
-Now, if it's not in the running apps tab, look for it in the All tab.
-After choosing Draw Something in the All tab, select Stop.
2) If the issue still persists, please reinstall
-Uninstall the app.
a. Open the Google Android Menu.
b. Go to the "Settings" icon and select "Applications".
c. Click on "Manage".
d. A list of installed applications will appear; select the game to uninstall and tap "Uninstall".
-Reinstall the app through finding the application in the Android Marketplace/Google Play.
-Re-boot your device (turn it off, then turn it back on)
. Last resort was to open a faceslap account, which i do not want to do, but i did and dammit after i log in using those credentials the screen goes back black again but is running in the background. This is what the developer suggested to someone on another forum, his problem was crashing tho. Oh, i did not help either.If you're using an Android Device:
-Select Apps.
-Uninstall the app.
