Root driod start up sound
Here ya go.
droid.ogg
If you are trying to put this on for your boot animation on CM7, you need to download this. Put it on the root of your sd and long press it and select "Extract all" inside are 3 files and 1 "notepad" document. Open up the notepad and it tells you where to move the 3 files too and where to put your mp3. (Has to be in mp3 format to work)
CM7 bootsound files.zip
i donloaded that zip last from from my phone and when i long press it it does not give me the option to extract all or anything like that.
ok used root explorer selected extract all , made a folder called extracted, copy the files and pasted them in the folders that the instructions said then moved the droid ogg into the system. media, ui file that holds all the sound files in teh phone and still nothing
