jbeckman4965
Replacement, Replacement
Okay, so mine was turning on and off, had to go to gingerbread keyboard, on and off status started becoming on then take back off take out battery, replace, the screen display locked up/froze, and the back became extremely hot (to even hold or touch)...finally had verizon do a whole reboot/master reboot, froze on them immediately after. Sent a replacement - low an behold only 3 months after purchase I get a "certifed pre-owned replacement"...which I bitch about, but to no success.
Loaded it up/turned it on as the replacement, did all updates via motorola site through USB port/computer, updates via verizon, and now off and on again, freezing, sometimes when you "waken" the screen it starts to darken slightly like it is going go sleep and you can't touch the screen to wake it completely, must turn off and on. Then the screen sometimes locks, or becomes minature of the screen size. Says I have no sd card, turn off and on, take battery out, reinstall sd card, still doesn't read. Finally turns itself off, comes back on, says sd card is bad and needs to reformat and I loose everything. and I didn't even take the time to add many apps back to the damned phone. Syncing to my ford is iffy - sometimes it comes on, sometimes not registering. And it didn't do my backup assist correctly from the last phone, and I got a really horrible threatening text from a number of someone I THOUGHT I WAS TEXTED - frightening.
Back to verizon, they call it in, they check it, gonna send me yet another certified pre owned replacement (cause those are better checked then the ones you buy at the store originally). Verizon said to bring to store to turn on, which I plan to do Saturday (cause what life could I possible have). WHAT ARE MY OPTIONS - If this doesn't work - I WANT THE MONEY BACK I PAID FOR THE DAMN THING and to try another phone!!>>?????
Anyone??? Does the 14 days count if it is a replacement?
