Is there a rooted ROM that makes it possible to use the Droid as a hot spot? I know the official word from MOTO is the hardware can't do it but my guess is that's not necessarily true.
I'm using Kangerade 5.0.9 with Kernel ChevyNo1 2.6.32-low V-1.2Gz... no issues.. only had to reinstall the Wireless Tether app once from the market.. i also use for the ''Encryption setup method" the value: wpa_supplicant
I'm not talking about tethering. I'm wondering if the D1 can act as a wifi Hot Spot where multiple devices can access the web via the hot spot using wifi to the droid.
yes its called wireless tether for the rooted droid. I have used it for connecting my Ipod touch and my laptop at the same time. its all wirelessI'm not talking about tethering. I'm wondering if the D1 can act as a wifi Hot Spot where multiple devices can access the web via the hot spot using wifi to the droid.
your right tether means with a cord but thats why wireless is before tether. so wireless means no wire right?Ah - I thought "tethering" required the droid to be connected to the computer with the USB cable. Here's why I was confused.
A tether is a cord or fixture that anchors something movable to a reference point which may be fixed or moving.
Thus I assumed the droid had to be connected with the USB cord.
