Same comands. And I'm running at 1.3 it's been stable but I bumped the voltage up to 63 no heat issue lock ups of anything
What I am not understanding from the OP is how to get it from stock parameters to 1.3 and to edit the voltage. I just don't wanna run commands and not know.
echo 56 > /proc/overclock/max_vsel
echo 1100000 > /proc/overclock/max_rate
echo 1 400000000 27 > /proc/overclock/mpu_opps
echo 2 700000000 38 > /proc/overclock/mpu_opps
echo 3 900000000 50 > /proc/overclock/mpu_opps
echo 4 1100000000 56 > /proc/overclock/mpu_opps
echo 0 1100000 > /proc/overclock/freq_table
echo 1 900000 > /proc/overclock/freq_table
echo 2 700000 > /proc/overclock/freq_table
echo 3 400000 > /proc/overclock/freq_table
You have to edit the setscaling.sh. Here's an example file, which would run the phone at 400/700/900/1100MHz (1.1GHz max):
Line 1 is the maximum voltage the phone will pass to the CPU.
Line 2 is the maximum CPU speed.
Line 3 through 6 are different CPU speed in Hz (from idle up to 100% usage) with voltages (the secondary two-digit number).
Line 7 through 10 are the same CPU speeds in kHz (minus the last three zeros from lines 3 through 6, to put it simply). Note that they are in reverse order. I would assume this is due to how the OS reads the mpu_opps table vs how it reads the freq_table.
What values will be stable for your phone will depend on your individual handset. Just like with a desktop CPU, each handset's CPU is slightly different and will handle overclocking better or worse at different speeds/voltages.
Yeah I had to run 1.2 at 59 but that's number basically is an amount of juice your phone sends to your cpu at that speed. That's why you don't want to go to high and if you drop it to low you can get reboots. Thus look for excess heat which could indicate your sending much power to it. Lockup and instability could mean not enough juice or your just running it to high
I know what the setting/number does, what I'm looking for is how it correlates into voltages. Obviously we aren't pumping 59 volts into our phones, lmao.
.... even after this, i do not get it at all. guess i will have to wait for something simpler.
echo 1300000 > /proc/overclock/max_rate
echo 1 300000000 27 > /proc/overclock/mpu_opps
echo 2 600000000 38 > /proc/overclock/mpu_opps
echo 3 800000000 50 > /proc/overclock/mpu_opps
echo 4 1300000000 63 > /proc/overclock/mpu_opps
echo 0 1300000 > /proc/overclock/freq_table
echo 1 800000 > /proc/overclock/freq_table
echo 2 600000 > /proc/overclock/freq_table
echo 3 300000 > /proc/overclock/freq_table
Just noticed my max is still at 56 this phone must be a beast
Wow wtf?! Hmm, you did up the other values as you went up, unlike me. Maybe if I changed mine too it would work. (ie. echo2, echo 3 etc)
Gonna test now.
If you're only increasing the maximum frequency (lines 2, 6, and 7), then you only need to increase the max voltage (line 1) and voltage for the maximum frequency (line 6). Increasing voltage to the intermediate speeds without increasing those speeds really doesn't do anything except stress the CPU harder when it's trying to relax.
Damn, even 1.25 at 60 and 61 hard locks instantly. I guess my phone just isn't that great. And to think this is my 5th D2, lmao.
Could it be because im not upping the other values as I go up, just the max values? Im leaving the other settings at what I had them at for 1.2Ghz.
Do not past 96 vesels, see my Quadrant score above![]()
