No stagefright improves h264 encoding and decoding it's much faster than opencore but it has bugs with streaming audio
Where can I get the file/DL instructions?
What kind of streaming audio bugs?
Links are fine if you have them for these questions. I looked for the stagefright insall and didn't find anything.
where do i go to see the voltages or that bar scale that is shown above? Is it an app or is there a test you run?
Ughh, so I don't know if I just have a sad sad phone, or I'm doing something wrong. Every time I load the module, I edited the voltages and speeds to 1.2, as soon as I run the commands to run the module, the phone locks up for a second and immediately resets itself. Am I doing something wrong or is my phone just not good for overclocking? I read the original posts and I think I have the basic jist of it. I had an overclock D1 that I never had this much trouble overclocking. Any help would be greatly appreciated.
Already have it I'll see if I unload my module and reload your if it will work but I believe the modules are different so for the d2 you would have to use the module in this thread
Cool ill try it out now
edit
just tried it works well getting 1850 in quadrant and 16.351 linpack scores any way to get it above 1.2
So has anyone actually taken a look at any of the proc files, specifically /proc/overclock/mpu_opps? There's a setting in /proc/overclock/mpu_opps labeled as "vseld". It might make sense that these are the default voltage settings. If so, my mpu_opps file shows them as 62/58/48/33 for each profile top to bottom. It shows these values regardless of my current speed settings, so I'd imagine they're the default voltages for 1000/800/600/300, respectively.
If these are indeed the default stock voltages, they may be a reason why some people are having problems when trying to overclock. The scripts included with the package from the original post show lower default voltages.
Is there anyone a bit more knowledgeable on the matter that might be able to tell if I'm right or wrong?
