last week, i was so excited to get the Droid 3 and have been having the worst problems with it. I almost suspect my phone is just a lemon..
anyone else have these problems??
google maps navigation: all addresses i try to navigate to the GPS consistently fails and will not register where I am or registers me within a 5 mile zone of where i actually am. My GPS signal is turned on and i have reinstalled the application to see if it was buggy.. i was traveling to san diego and got severely lost and had to rely on the actual map view to figure out how to get to where i was going.. the directions were consistently inaccurate. My Droid 1 (or the first droid on the market) never had any navigation problems and was excellent
speed: the speed of the phone opening apps is slower than my droid 1. its a 3-5 sec delay before the app opens such as facebook or calendar
camera: its a bummer the only button you can take a picture with is the touch sensor button, taking photos at night are beyond poor, fuzzy and unusable with the flash.. many of my friends cameras were taken decent night photos and i was all excited to try out my new droid 3 and horrible unusable results. i double checked, triple checked settings and it was all set
actual phone dialing: took 3-5 seconds to pull up contacts and when i dialed someone, sometimes it would not respond to the end call button and i couldnt disconnect
speaker phone: sucks on my droid 3.. i normally use speaker phone when im driving and i am unable to use this feature with my driod 3 bc i've received consistent complaints that my caller can not hear me... (compared to me always using speaker phone on my droid 1 and there was never a problem)
does anyone have these problems?
I have none of those issues. With regard to everything besides the GPS and speaker phone, it sounds like you have some offending app taking too much CPU time. The camera does take a few seconds to load, but most other apps should be faster than the D1 and open fairly instantaneously.
With regard to the GPS, I never had location problems that you've described. Mine is as accurate and responsive as it should be. While the above is most likely a software issue, the GPS problem you mentioned is more likely a hardware problem with the GPS antenna.
I've never had anyone complain about my voice quality and the speaker phone is definitely loud enough for me. I have a LOT of work done to my car, so I use the hands-free through my radio so that I don't have to use the speaker phone there. I have no problem hearing it if I use it in an average public environment, though.
I'd take it to Verizon and have a tech look at it. Maybe they can isolate the app causing the unresponsiveness for you and tell you better whether the GPS problem is hardware-related.
