I have the same problem with my droid 3, the problem started about a week ago and got progressively worse. It is at the point where i cant get past the lock screen because the touchscreen wont work. The screen often displays noise static and glitches visualy, but then an hour later it is fine.
I have factory reset it and rebooted it via key commands and it still does the same thing.
Has anyone found a cure to this problem?
