I Have a DROID 3, it started acting up months ago, i would have to take the battery out an re-insert it over and over an to get it to boot up. It would power on after about 5 re-inserts. Due to the phone acting up i had to do this numerous times. One day i had to do it again, i got it back on and it was running for about 5 minutes an then the Screen blanked out (was still on but nothing showing, Black screen with backlight on). i Pulled the battery figuring i'd just do the same old re-insert method and and its been dead for about 2 months. i JUST received a new battery, tried and still no luck. The New battery, shows the White LED while charging, it flashes but slowly and then after a while it goes solid, and stays solid. Any suggestions?
EDIT: when there is no battery present i get the White light. when a battery is in, no white light and nothing on screen
