Root Droid Boot Loop & Factory Reset a No Go. Help!
I think I have read 15 post here so far with a similar problem but no one seems to have the exact problem or a solid solution
My droid is rooted. Has been for over a week now no problems
The problem came with Metamorph... UGH
I applied some framework res, rebooted and my clock wasnt showing
I found a file for MM to change the clock color to orange.
Installed
Asked to reboot...
The looping begins.
I had clockwordmod installed, i used it to recover my phone a few hours ago. Now all i can access is the standard recovery mode (none of those options work) and Bootloader..
I was reading on rsdlite and reflashing so I got all the drivers etc but could find no guild that was trying to do what I need!
Is this problem fixable because I feel like it is. I actually got to the setup wizard HOW idk it happened once and immediately had a force close box that restarted the phone and the loop began again.
Any help would be fantastic and SORRY for another boot looping thread.
this was my last option but with no success on previous post by people and maybe not knowing what to search for I gave in
ty:D
if you could still boot into a useable rom,i was going to suggest reflash clockwork so you could boot back into it.
if not,you can use rsd lite and a sbf file to reflash clockwork.
if neither of those 2 things are what you did,please explain your solution so others will benefit in future searching :)
I had originally tried to unroot and flash with RSD Lite and had no success. I ran across an unrooting guide and it had a 2.0 sbf download.
I used RSD Lite 4.6
Already had the latest motorola driver
Ran bootloader
Selected the SBF
Ran it and it worked.
I tried it previously with a 2.1 sbf version but always failed..
The only problem i am having now is updating my phone from 2.0 back to 2.2.. Sd card and the update folders dont want to work
