Help Droid Charge LED Notification Light
There is no notification light on the Charge unfortunately. You can try downloading NoLED app from the market. I'm not sure if it will work with the Charge though as its meant for the Galaxy S, but I would give it a try.
What a huge disappointment. Thank you so much for your quick answers and I will definitely try the NoLED app. If it doesn't work I'm exchanging for the Motorola Bionic,
NOLED was irritating to me. I didn't like it, already uninstalled it. I just see it as a battery drainer. I already have 4G to take care of that, lol. I'll just deal with the no light.
You must have some crazy inside connections of you're getting that Bionic!!
I found the solution to this problem!!! Download the SMS PRO app for the phone. You can customize your sms with differnt colors and backgrounds, no more ugly brown :rolleyes:. The best thing of all, it has a setting to "wake" your screen when u receive new msgs AND u can set it to remind u in set intervals when u have an unread one! :D
I had tried the NoLed app prior to this and it worked "OK" but SMS PRO is sooo much better. I ended up deleting NoLed :p
i disabled notfications on the stock sms but a little orange block still appears under the stock sms how do i rid of that- i also have texts going to both smspro and the stock one but i dont care as long as the orange popup next to the green message stock thing goes away
Is this app also called go SMS pro? I would really like to download an led notification for my droid charge. Thanks
Itsm is go sms pro but there is no led for the charge or any samsung phone at that..maybe others have it but there is no led for the charge the things u see at the top of your phone are sensors and your front camera...
Unbelievable. This is almost a fatal flaw for this otherwise great phone. I have had it only a few days. Might consider returning it, but what is there to replace it. Dang!
I dont get how its a flaw...it should be simple to just pull your phone out, push the power button and see if you have any missed calls or txts or emails..i dnt get how its a flaw...its actually better because now theres now annoying light blinking in your face when your trying to sleep...
I think NoLED works pretty well and doesn't seem to drain my battery. I often leave the phone on vibrate at work and walk away from the desk to do stuff. Nice to see if there are notificatins by just glancing at the phone. I miss the light too but find this works pretty well.
Coming from the Motorola Droid, the blinking LED at night was a non-issue for me because I had the multimedia dock. When the Droid was docked and the screen was in its dim "night mode", the LED would not blink.
On top of that I had the CM version of Desk Clock so I customized the time color to be really dim. I just might keep it around as my desk clock.
And yes, I consider no notification LED to be a flaw also. It was almost a deal-breaker for me. Luckily I found out about NoLED and it's holding me off for now.
In use the sound and vibration reminders every 5 minutes until I answer. Go SMS and handcent both have those options. You can very the reminder time and interval. I do not miss the led light since using these.
Am I crazy but it seems like there are three tiny led's on the top right side of the phone (not the front facing camera). It seems like the hardware for notification is there but they are not tied to the software. There is no description of what these are in the handbook etc.
I see the same thing. I wonder what they are??
Those are the proximity sensors. They are for when you put your face near the phone it will turn off the screen while you're talking. They also detect a dimly lit room and trigger the button lights to come on. You can try this by waking up your phone in a lit room and putting your finger over the sensors. If everything is working correctly, the button lights should light up when your finger is over the sensors.
I just want to add that I too was at first disappointed that there was no notification light on the charge....but than about 4 maybe 5 seconds later i was over it!!!
Like the other posts mention, that LED light not on this device is a blessing. I agree with someone else that said something about it blinking in a dark room while sleeping, that was something that bothered me too.
But would I NOT call this a flaw, and in no way would i return a phone for that reason. At the moment, this is the best verizon android phone out. Best battery life and the screen is amazing.
I completly understand that it is something that some may be used to, but would not let it make me get another phone.
I also use the sound/vibration feature with go SMS or hand cent. Totally solves the problem without the annoying light. I do the same with my gmail and voicemail.
I hate the lack of a light too. I installed NoLed but my system lagged and the battery drained faster. It seemed a little buggy. I'd try to wake my phone up and it would freeze for a bit. I have GoSMS too and will try the notification settings, but I really prefer an LED to the phone vibrating. Often I have my phone out of my pocket and on a shelf somewhere across the room while I'm using power tools. I could always see my blackberry's light flashing, but I'm not always going to hear it vibrating. Oh well.
I understand people not liking the flashing light, but those people can always disable it. It really does seem like a major oversight to not include one.
