Droid Eris Video Player???
Thanks. I was trying to find it before adding any videos. Now that I've added a video I can see the playing feature.
When I go to watch a video in the built it player, the video lags. When I attempt to watch a video with meridian, it crashes.
theres an app on the market that i recommend called "video player"
its got pretty mixed reviews, but i got no problem with it its worked flawlessly since day one.
Which codec and what framerate are you encoding the video at? Are you trying to play videos with a resolution higher than the native resolution? I'm encoding videos with h.264 at 23.976 fps and AAC audio and they run great. The are all within the native resolution (480x320) and encoded at around 500 kbps. The videos look great and run well with built in player (and even plays well zoomed), mVideoPlayer, and Act 1. For some reason the Eris had issues when playing videos I encoded for my PSP and the only difference was that they were in encoded at 30 fps.
It the movie Office Space (Great movie). I converted it a lower encoding which is 704x384 and 28.8 frames per second. The audio is 48,000 Hz @ mp4a. I'm assuming that the encoding settings I used is what's causing the lag.
Do a Google search for video to iPhone converter. It is a nice little program and the videos play very well on the stock player.
I'm not clear on why you would encode at 704x384. There is no advantage to this res on the Eris. Even if it is playable it will probably look worse than one at native res because the Eris has to scale it. Go 480x... I would not talk about specific movies..
