droidwalker
Droid 3 comes with "QuickOffice". It has four applets (Spreadsheet, Word, Presentation, and PDF).
For example, when you create your spreadsheet, you can save it as current XLS, or backwards compatible to Excel 97-2003 format.
When you launch QuickOffice, the main page has an icon "Browse". Tap the icon, you next screen becomes a "file manager" where you can lookup files, rename files, delete files.
To expand the screen size, use your two fingers to expend (zoom 150%), or pinch (to minimize the view).
After you type some text in a cell, when you highlight the cell again, the right edge has a knob. Tab the knob, a mini menu opens (to cut, copy, or paste).
When you tap your phone's Menu, the spreadsheet opens with toolbar at bottom of screen. You can scroll right, to see more icons (tasks) on the toolbar.
When you save your file, you can create a folder, say, "MyDocs" and then save your excel file inside this folder.
Later when you launch our QuickOffice, you can drill down to this "MyDoc" folder, you will see all your files, excel, word, presentation.
Finally, you can email your docs to yourself or to a colleague.
Droid 3 is becoming not just a walking dictionary, it is a wonderful (productivity device) that happens to fit in your pocket, on the road, at a park, to do research or to create your own documents, and then share it with a friend.
Isn't this what a mobile device should be?
). I was incredibly disappointed when I realized the app was really just a link to their web interface with a better menu.
