I am a bit worried about the GPS if you read the Droid Preview from BJR Motorola Droid Preview : Boy Genius Report
It says "Google Voice obviously works flawlessly (we
i'm looking for the ability to map where i've been - specifically, off-roading or hiking. can this GPS map my location in real-time and store the info?
Absolutely. Check out the free app My Tracks for Androidi'm looking for the ability to map where i've been - specifically, off-roading or hiking. can this GPS map my location in real-time and store the info?
A cell signal or data connection is not required to record GPS tracks. However, if there is no data connection, you will not be able to see satellite imagery or a map. Instead, you will see a grey screen or partial map. Tracks, represented as simple lines, can still be recorded even if there is no data connection.
From the My Tracks FAQ:A cell signal or data connection is not required to record GPS tracks. However, if there is no data connection, you will not be able to see satellite imagery or a map. Instead, you will see a grey screen or partial map. Tracks, represented as simple lines, can still be recorded even if there is no data connection.
