Don't think it will work, I have the same problem... drove over my Dinc-1, ASSurion is sending me a Dinc-2 today. I also bought a new extended battery a few days ago...
From looking at the specs for the battery itself, it looks like the Dinc-2 battery is 5mm wider than the battery for the Dinc-1. Bigger problem is that the case of the Dinc-2 is also bigger so I doubt the extended battery case for the Dinc-1 will fit. I will know for sure tonight.
