Help Droid Inc Restarting
hakoreh
Member
I know there are other threads but this is strange since my phone never ever did this. All of a sudden the last two days my phone has been restarting randomly, mostly like two minutes into using the phone. It doesn't though go to the HTC Incredible screen but rather the HTC Quietly Brilliant, quickly to Verizon Wireless screen and into the OS. I see the CPU doing heavy duty work using all but 100% yet I checked System Panel and I don't see anything using that much usage.
Again this has just started the last two days or so. Never before have I had this problem. Anyone else just in the last few days?
yes
all i have installed is
gtasks
estrongs file explorer
lookout
live scores
handcent
pure grid calendar
smooth calendar
multicon
traffic jam free
beautiful widgets
impossible level game
twidroyd
ebay
battery left
wheres my droid
book manager
barcode scanner
wordwise free
xscope browser
touchdown
mobile buzz widget
sound manager
swype
I posted on one of the other threads on the same topic. Honestly, I tried all suggestions. The problem just kept getting worse. Only thing that fixed it was getting a replacement. Call VZW customer service from a different phone. They will likely make you do a battery pull, then a hard reset, then replace your phone. Good luck.
I have the same problem. Mine resets when I sometimes have apps to install or it just resets. My power amp unlocker doesn't stay in my apps. I have no new apps. Just the gingerbread. The prblems started when I got gingerbread.
