Droid Incredible Description
Status
Not open for further replies.
T
techno-update
Guest
The Droid Incredible by HTC is a high class phone. It has a 8 mp camera with dual led flash that I found takes great pictures. Plus, it has great video recording. With a 3.7 inch screen, it is not small but not too big either. It also has a great display, with 480 X 800 WVGA resolution. Since this phone is mainly made of plastic, it is fairly light. Because it is so light, it will sometimes just slip out of your hand. The back of the phone is very smooth. The micro usb charging port is annoying because you can not use the usual mini usb. Another weird thing is that the charging port is on the side, which means that you can not get a dock that charges. It can have up to 40 GB. With 8 GB internal memory and an optional up to a 32 GB micro SDHC card slot, it has a lot of memory. This phone is fast too. With a 1 GHZ snap drag and processor, you will not be waiting with this phone. Another great thing is since it is an android it has access to the android market, which new apps are added to each and every day. The android market is growing at a faster rate than Apple's app store. It features HTC Sense, which just adds a nicer look to the overall software. Some do like the default android software even though most don't. Though it has no physical keyboard, it has a great virtual keyboard. The phone has the featured HTC keyboard. It has a useful trackpad, mainly for going between words or hitting small things on the web. It has Flash 10.1 built in and is great for watching videos online. It has the stock HTC web browser, though I prefer the Dolphin Browser HD. This browser may load a little slower than the default browser, but it makes up with this with a cool design. You just slide to the left to get to the bookmarks tab. This makes it a lot faster when trying to get to bookmarks. This phone has a small battery at 1300 mAh, though it will get you through the day if you don't use a lot of internet. If you are a big internet user and really need a big battery, you can get a 3200 mAh battery. This will cause you to have to change the back cover. It runs on Verizon's network, which seems to be really good. Calling on this phone seems to be really good from both ends of the line. A lot better than the 1st Motorola droid. This is a overall great phone. If you are on Verizon Wireless, I highly recommend you get this phone.
I don't really see this as necessary and it probably will not garner much discussion, so I'm closing this.
Status
