Droid Incredible has best HotSpot on 3G
I cant wait for 4Q and 1Q of next year. LTE is just going to embaress Sprints Wimax crap. And i cant wait to see the lineup of phones either.
I don't know about you guys, but I'm getting a consistent 500kbps or lower during the day from my phone alone on 3G. I can get up near or to a full 1Mbs. I don't know if it's just my area or what, but my speeds suck between early morning and late night, obviously.
How so? and have you gotten the bill yet to make sure it's free? lol
For God's sake, let's not start this again. Take your "I'm smarter than you" attitude elsewhere. This is a discussion of WiFi hotspot speed.
Attitude? I gave no "attitude" at all, all I asked was a simple question... you seem to be the condescending one here sir...
I still prefer my Stock 2.2 with ##778 Edit. :D
I use the ##778 as well, i also have the wireless tether for root installed, I tried both, but I can't tell a speed difference, I'm not sure if I'm going to get charged for it yet tho bc my bill doesn't print until the 10th.
For some areas that is perfectly normal
It shows up like your using your phone to surf the web. Just don't go crazy and start downloading large files or streaming movies and no alarms will go off at VZW.
Mine works great, I tested it out this weekend. Non-root + free teather = WIN!
I hear ya. I need to sew up the holes in my pockets where VZW keeps craming their hands in them constantly. I'm not giving them any more than I have too. I have 5 phone lines and a Wireless Hot Spot MIFI. I've bled all I can bleed. I need a transfusion.
What is the ##778 edit?
From an earlier post;
Steps:
1) Dial ##778, SEND
2) EPST dialog comes up. Select 'Edit Mode'. Enter SPC (000000), hit OK.
3) Scroll to down to 'Security', select it. Change 'S.IP DUN User name' to yourvzwnumber@vzw3g.com (from yourvzwnumber@dun.vzw3g.com)
4) Hit back arrow to go back and go/select 'M.IP Default Profile'. Change 'DUN NAI' to yourvzwnumber@vzw3g.com (from yourvzwnumber@dun.vzw3g.com)
5) Hit menu button, and 'Commit Modifications', phone will save changes and reboot.
Basically remove the letters DUN from the line after "your number@
and yes then the 3g mobile hot spot button works fine
Amazingly enough, it worked! I was having difficulty earlier, but now it seems to do what you say. In fact I'm using it right now.
So now I have rooted WIFI tether
3G HOTSPOT
and Wired USB tether
For FREE!
