droid incredible screen tint
cc6547
i was recently trying to fix the charging port so I opened it up by taking out the 4 screws. I fixed the charger by gluing it back in place and ten put it back the ay I took it apart, quite simple, however wen I turned it on I noticed the screen now ad a peculiar rein tint to it tat wouldn't go away. it is really bothersome so if someone could tell me how to fix it, much appreciated.
I think glue is probably the worst thing you could have put in there. I've not took one apart, but I think you would have needed to solder that
It was originally held in with glue. The price I was fixing was made of plastic. Just in case ill scrape it off to see if that does the trick.
Ahh, I see. I don't even like playing with charging ports on a laptop, and there is way more room to play with there.
You are braver than I! 😁
Chances are something else is coming loose and it's not the glues fault.
Haha ya I figured its an old phone and its wifi only so why not experiment on it by opening it. In fact I was thinking of trying to make it wirelessly chargeable since its already rooted and runs cynogen mod XD
Nice! If that works definitely tell us about it. That would be pretty cool!
