Help droid incredible technical question
ash1981
So, I am using pod to pc to sync my ipod to iTunes & then to sync my droid inc. the program I am using is tune sync. I've been using it for a week now & have had no problems. It wirelessly syncs with iTunes & has been great. Today is the first time I've tried the pod to pc. It showed that it was syncing. I went to look at the screen & it went black. The little green light is flashing & it's said droid like twice, but I can't get the screen to come back up.It is fully charged. Any ideas on what I did? Any suggestions on how to get the screen to light back up again? I've tried to power it off/ on, but can't tell is it's working.
I think I would try a battery pull. If that doesn't work, you might need to talk to Verizon...
