Root Droid Keeps rebooting
Picaso86
Member
I am running the new NexBeast ROM (Froyo) stock kernel. Everytime Im on a call (4-5 mins into the call) my phone keeps rebooting. any ideas of whats happening?
side info: I havent updated to the new baseband - I dont know if this could be the issue... Please help its really annoying :confused:
Sorry, I failed to thoroughly read your first post.
I am clueless on this one, maybe another member has the same issue. I don't know if it is because it is set so low, or what. I am miffed. I know alot of the people here run it at 250min, so I don't know.
Hopefully someone else can help ya out.
Try changing your kernel - look at the Froyo kernel thread in this forum. What your running (P3Droid) worked for me, but you could also try one of Chevy's low voltage kernels...I'm running that now and it seems to be very stable.
OK guys just an update - the problem was being caused by my profiles in SETCPU. I set them up from 250mhz to 600mhz when sleep and 250mhz to 500mhz if the temp. went over 42C/102F ...so I took my profiles "OFF" and deleted the YouMail app. my current settings are from 400-1.0mhz.
PS: for some reason if i lowered to 250mhz it will caused random reboots. thanks for all your help guys :)
LONG LIVE DROID!!!!
