droid mms question please help
cak
I've had my Droid about three weeks now and my wife has too. Well when I get a
Picture text the pic is really small. My wife gets the same one hers is big. How can I fix mine. I did the forced 2.2 install but is was like that before I put 2.2 on it. Thanks in advance, Chad
I use "Handcent" for mms. It works great, and when you get a pic, it comes in small. You just touch the pic and it shows it large. Great app, can be found in the market. Hope this helps a little!
The stock app does that too. Tap on the pic, and it will open in the gallery, enlarged.
I guess I should have explained it better. When I get mms some have a play button over them. When I open them they are small and if their is more then one pic in that text then its like a fast slide show with play controls at the bottom that do nothing. And regular ones with picture and text will flash fast. Why is this like that. My wife's which we got the same day isn't like that. A buddy's isn't either. And regular pics without the play button are small to. I can send them to my wife's and they are normal.
In your messaging app, what settings do you have enabled versus your wife's?
(Run the messaging app, then hit the menu key)
They are all the same as hers any other ideas would be gratefull. It kinda sucks to have a decent size screen and have to squint to see the pics lol
It has to be some setting on yours and not in hers.
Are all your apps identical? Have you rooted? Have a lot of apps installed?
I just got home from Verizon. I took it back and got a new one. They didnt know what was wrong with it either. I am sure it was like that from day one tho. Oh well got a new one and its fine now lol. Thank you for your time now I need to update/get new update for the new droid lol.
Oh and to let people know because I read somewhere someone said that you cant get new Droids any more WELL I JUST DID
