I use Media Monkey and it's worked fine syncing my music to the Droid. My last sync though, I changed some play list. The Droid now shows some of them, not others and one that was renamed shows up with its old name.
Media Monkey writes the playlist in m3u format to a \Playlists directory. The files in that directory are fine. The droid appears to be reading the playlists from somewhere else.
Any ideas?
Thanks
Any ideas?
Thanks
