Well, I finally turned to this forum to deal with my Droid frustrations.
What apps do you have installed?
Do you press the power button after ending calls? I guess I'm anal and a habitual person. After I end a call or even look at the screen I quickly press the power button to not waste screen juice. Do you do this as well?
you mentioned though that it will call this person even when you don't put it in your pocket - any apps?
DROID PROBLEMS..... WHERE DO I BEGIN!
Picked up the phone three weeks ago with the greatest of expectations. Wanted an iphone for years but did not want to move from Verizon. Finally I saw Droid as the answer. Prepaid for the phone from Best Buy and picked up early the morning of the first day. I had them install the plastic screen guard..... WHICH may be what is leading to a lot of the touch screen and proximity problems.
Here is what I have experienced thus far:
Very poor battery life. Have to re-charge some times twice a day.
Battery door falls off frequently.
When on a call, frequently the screen goes black and cannot get it to wake up to either open up the on screen key board so I can put in my pin for e-mail..... or to hang up after the call.
Constantly have to push the on -off button on top... to get the screen to shut off or to turn on.....and frequently have to search to find the top of the phone from the bottom to locate the button.
Signal strength compared to other phones I have used is not as good
ONE BIG PROBLEM.....The phone frequently "pocket dials" the last call I just logged off from!!.
Touch screen... especially the for symbals at the bottom are not responsive to touch.
Other minor irritating problems but not as important.
Tomorrow.... I am back to Best Buy to give the phone back and got my old phone re-activated..... It worked for the past two years with NO PROBLEMS..... and it was one of the FREE LG phones from Verizon.
Verizon has a great network... ultra reliable but they and Motorola really blew this opportunity to one up the i-phone.
STF 85202
