Help Droid Razr Battery Life - Worried and Need Advice
Alvas
First, a little backstory. Last Sunday was my birthday, and I was originally going to get a PS Vita. However, after realizing I wouldn't have enough money to buy games for it, I decided instead to get a smartphone. With only 24 hours left until my bday, I didn't have time to do much research. Anyway, that was my little backstory so you understand this a bit better.
So I ordered the Droid Razr from my local Verizon Wireless Premium Retailer. After putting the Razr and iPhone 4S head to head, I decided the Razr was the phone for me. But while I was researching, I didn't see all the complaints about the battery (I watched mostly mainstream reviews, which didn't gripe about it), or the fact that the Razr Maxx was coming out in less than a week.
I picked up the 16gb Razr for 200, which is the highest price phone I can get. However, I am worried about battery consumption/life, and whether or not it will get me through my day on a single full charge. So I think if I just tell you what I will probably be doing with my phone, maybe you guys can advise me:
1) HEAVY Texting - probably a few hundred text messages a day
2) Moderate Web Surfing and Email browswing - via WiFi
Smart Brightness Settings - Low when I am inside, only high when outside, which won't be often
3) There is no 4G in Burlington, so no 4G connection, however there is 4G in Albany, which I go to every other weekend and spend school breaks/summer, so we will say moderate/low 4G use, and when I have that option, no 3G use
4) Little 3G use, only when I want to check email when on the go, and maybe some web surfing via 3G when I'm bored in an area with no WiFi... but still, we'll say Moderate 3G use to be safe
5) Probably not much video watching, maybe a youtube vid here and there, but never more than 1 hr per day, and always on WiFi
6) Minimal/Moderate calling, less than 2 hrs calling per day
7) When not in use, phone will be asleep in my pocket with 3G/4G disabled and with sync options set to probably like 30 mins
8) On device music use, and maybe some Pandora via 3G when driving, but mostly on device music use, no internet/3G
So with all that, will the original Droid Razr be a phone I can work with? I will never play games on it, I use my 3DS for that, and like I said, all in all, an entire day of school, I will probably use my phone for video for less than an hour. Texting is the only thing I will be doing damn near constantly, and that is what worries me. Keep in mind, I CANNOT upgrade to the Razr Maxx, as much as I would like to. No, if this phone won't work, it's going to be the iPhone 4S for me. I just never know what people mean by "heavy" use, and I don't know if what I plan to do with it qualifies.
Also, I almost never have days where I have to go 9-10 hours without being home and being able to charge, or driving and using a car charger. I have classes sporadically, and I can charge in between them, but I am looking at worst case scenario. If I needed the phone to live through an entire 9-7 day or so, would it make it with my amount of use? I really hope this phone will work out for me... and sorry for the HUGE amount of text
I think you should be okay if you are light on 4G. LTE kills the phone battery and if you turn it off you should be okay.
awesome! And I actually just got a deal on a 2600mAh battery extender accessory for 30 bucks, that will ensure that even if I run low on battery, I can just plug it in without needing to be close to an outlet. Problem solved!
Well it is 3:30 pm and I unplugged my phone today at 5:30.
Have data turned off because I don't need to use it at work.
Did some medium texting and a couple of calls, not long conversations.
But I am at 70% batt......
U have the batt extender for when u are out and about so you should
be good......
Also
be good......
Also
what is your screen brightness at, and are you using any programs like smart apps or juicedefender to max out your battery life? Also, you mean you unplugged it at 5:30 in the morning?!?! Because 10 hours of life doing medium texting and a few phone conversations and you're only down 30%? That's crazy good.... much better than I had expected
"smart apps"? what's that?
Mine would last about 3 days with light usage if I have 4G off the whole time. If you mainly use your phone for heavy texting, then there's no reason for you to have 4G on, so I think you'll be fine. Do note that though streaming videos will also drain battery very fast on just about any phone out there.
I have brightness on auto and I am using both SA and JD.
I'll only have 4G on when I go to Albany, so I guess I'll only have to deal with it then, if I even bother using it at all.... main point is, my 4G use will be incredibly rare, so I won't have to worry about it. Now 3G, that's a diff story...
Good Lord..a "couple hundred" texts a day?????
I would not worry about the battery and start looking for a good orthopedist for your pending carpal tunnel surgery...
lol what's worse is that I am also on my computer and gaming a lot.... my wrists are doomed
World of Warcraft put a hurting on my wrists and eyes....not to mention my sleep :).
Good luck with the battery
Turn off 4G if you use Wifi and can live with 3G speeds. 4G is a killer on your battery even if you don't use it at all during the day.
With 4G on my battery would be around 10%-20% at end of the day from a full charge. With 4G off, I now end up right around 50% with heavy usage.. or 60% if no one calls me.
I use wifi mostly so turning 4G off was a no brainer.
great news... like I said, will only be using 4G when I'm at home, and even then, never for long periods of time... and that's only if my 3G speed slows to a crawl
