What does the code square in the "smilepak" link do?
Before the 2.1 upgrade my home page rotated (and yes i have the check box selected in settings) and after 2.1 it no longer rotates when I turn the phone sideways. Is there a way to fix this without getting a home replacement?
Thanks Ro
All's I know is that I didn't Change any settings and now it doesnt rotate the screen. I have the stock home and I tested it on my friends phone and hers doesn't rotate either. If any one can think of something I can try I'd appreciate it its annoying to not have the rotate feature and I don't want to change from the stock home.. thankd
Love LauncherPro!
I now have the equivalent of 10 home pages since I can scroll the shortcuts at the very bottom for an additional three different groupings.
One can, also, set the number of primary home pages from 1 to 7.
wavesecure and lookout do that. Both require an annual subscription but they have quite a lot of features.Is there a way to remotely wipe all your contacts from your phone if it gets lost?
If you go into facebook, menu, setting, there's an option to sync your FB friends with only those that are in your contact list or to turn of the sync completely if I remember correctly.I have a new droid and i am also on fb....all of my fb friends birthdays transfered to my phone calendar and i do not want them there....it's just too many, my calendar has a birthday on it almost everyday. how do i change this?
That is the multitasking menu. List of your 6 most recent apps.
For those that don't like the slider thing every time you want to wake the phone, get this APP. Set it to "awake stay" mode, and just like that......slider gone. I love this feature cause it's annoying to me that I have to press the lock button AND the slider to unlock the home screen.
When you want to lock the screen again, just hit the top button.
I tried this and it didnt work for me. I used your example and tried diffrent variations and no luck . How man pauses need to be in it?
Its sounds good... but can you break down the steps a little more... thanks
I've been reading a lot of the posts and although most of them are very helpful, I haven't seen anything regarding Contacts. Is there a way to set up my contacts into groups/folders so I can easily send 10-15 friends an e-mail without scrolling through my contact list and attach them?
[ let's say "In n out"
Yes lets say "In n Out"!!! Those are good burgers!!!!
