chucksartoris
Has the new Patch fixed this issue?
Has anyone had the issue of your phone not doing anything when someone calls?? I've seen it with my own eyes: someone calling and my phone doing nothing. My phone is usually on vibrate because I have a 3 month old. Today is the second time it's happened, the first time was the first of the year. I just thought it was a bug with the new year. Any help would be greatly appreciated! This mommy is kinda freaking out
I have this issue as well. I thought perhaps it was because my Bluetooth was connected, but in my pocket, that I was not hearing my phone ring. So I tested that theory.
I called the phone from my land line with the Bluetooth on and it did not ring but the Bluetooth was telling me I had an incoming call. Then I turned off the Bluetooth and called and the phone displayed incoming, but did not ring nor vibrate although it is set to do both. So while the call was being displayed I hit the vol up to ensure it was turned up, the volume indicated full up, and the phone began ringing and vibrating.
I then reconnected my Bluetooth, dialed in again and lo and behold, the phone rings aloud, vibrates, and the Bluetooth tells me I have a call incoming.
So now what remains to be seen is how long this will stick.
Verizon asked me to clear my cache partition, and I think I did so, prior to conducting this test.
I followed the prescribed steps but they don't quite jive.
I selected the recovery mode per the steps to scroll using vol down, and then it says to select recovery mode using vol up, but vol up simply scrolls in the other direction from vol down, and changes the mode.
So I had to punch the power button to select. From there it indicates "no command" so I have no idea what's happening. Then after waiting a while the phone powered up.
Did it clear the cache partition? Who knows?
But "whatever"!
for the moment incoming calls ring, vibrate, and tell me over Bluetooth.
As I said "we'll see how long this sticks".
Sounds superstitious, as opposed to a fix, but the outcome is thus far undeniable.
I have never previously wiped cache. The phone never did anything weird until these recent episodes.I Wipe Cache Partition every Saturday (my maintenance day). Not doing it results in it becoming contaminated over time and performance really suffers.
I've noticed that the time to wipe is about 6-7 minutes on both the Turbo and the Maxx. No one has yet explained why it takes so long.
... Thom
Have you tried running in safe mode?I have never previously wiped cache. The phone never did anything weird until these recent episodes.
After wiping cache with per Verizon's suggestion, I was hoping it would cease cycling power on its own.
But later in the afternoon yesterday, it once again cycled its power.
recap of symptoms:
The phone began power cycling no more than once a day as of last week.
I have had this phone since November and it never did this before.
It is running 4.4.4, and was last updated in February.
I have made no changes to my phone recently.
And my previous Turbo did the same thing after owning it for a while.
For that phone they had me do several things that did not work.
replace the SIM card, factory reset, gradually reinstall apps to see if one had anything to do with it.
Then when all else failed, replace the unit (last November)
And now working with VZ, when it power cycles itself I dial 1111 to pin point the time of day so they can see if anything relates. We will gather more facts about "when".
I've had a bad browser update - complete with a runaway condition we call a memory leak - produce nearly identical results on another phone model fwiw.
"Gradually reinstalling apps" sounds good on paper but is really worthless if the last one or near to it is an offender. Iow - can work, often works, can't be guaranteed to work.
If a phone's recovery clears it with a format command, it's really fast. If it uses a verified remove of each item instead, it's going to take longer and scale up in time for more items.
