Droid Turbo Reference and Tips
Droid Turbo – Releases​
24.91.5 - OTA - 2017.03.11
DROID TURBO - Model number
6.0.1 - Android version
January 1, 2017 - Android security patch level
I15.MOT.XT1254.0 - Configuration version
MDM9625_41.51.07.22.04R QUARK_CUST - Baseband version
3.10.40-perf-g1577812
hudsoncm@ilclbld33 #1
Mon Jan 30 08:46:52 CST 2017 - Kernel version
24.91.5.quark_verizon.verizon.en.US vzw - System version
MCG24.251-5-5 - Build number
24.81.5 - 2017.01.nn
24.81.5.quark_verizon.verizon.en.US - System version
September 1, 2016 - Android security patch level
MDM9625_41.51.07.22.02R QUARK_CUST - Baseband version
3.10.40-perf-gcd46769
hudsoncm@ilclbld32 #1
Thu Nov 3 16:34:02 CDT 2016 - Kernel version
MCG24.251-5 - Build number
23.21.49 - 2016.05.11
23.21.49.quark_verizon.verizon.en.US.vzw - System version
2016-04-01 - Android security patch level
5.1 - Android version
F14.MOT.XT1254.0 - Configuration version
MDM9625_1040651.11.05.16.03R QUARK_CUST - Baseband version
3.10.40-perf-g1e2ae8d
hudsond@ilclbld26 #1
Thu May 5 09:23:30 CDT 2016 - Kernel version
Thu May 5 09:15:28 CDT 2016 - Build date
SU4TL.49 - Build number
23.21.44 - OTA - 2015.10.10
XT1254 - Hardware SKU
MDM9625_104651.11.05.16.01R QUARK_CUST - Baseband version
3.10.40-perf-g90ddf4a
hudsoncm@ilclbld79 #1
Tue Sep 1 22:50:23 CDT 2015 - Kernel version
23.11.39.quark_verizon.verizon.en.US vzw - System version
SU4TL-44 - Build number
Tue Sep 1 22:44:14 CDT 2015 - Build date
23.11.39 - OTA - 2015.07.27
3.10.40-perf-ga0ad644
hudsoncm@ilclbld96 #1
Fri Jul 10 02:35:55 CDT 2015 - Kernel version
SU3TL-39 - Build number
Fri Jul 10 02:25:57 CDT 2015 - Build date
23.11.38 - OTA - 2015.07.01
MDM9625_104651.11.05.16R QUARK_CUST - Baseband version
hudsoncm@ilclbld98 #1
Mon Jun 22 19:23:04 CDT 2015 - Kernel version
23.11.38.quark_verizon.verizon.en.US vzw - System version
SU3TL-38 - Build number
Mon Jun 22 19:16:32 CDT 2015 - Build date
21.44.12 - OTA - 2015.03.06
21.44.12.quark_verizon.verizon.en.US - System version
Motorola Mobile Computing System - System information
4.4.4 - Android version
MDM9625_104351.17.02.71.13R, QUARK_CUST - Baseband version
3.10.40-perf-g9df477d
hdsplat@ca101lnxdroid72 #1
Fri Feb 6 15:33:41 PST 2015 - Kernel version
Fri Feb 6 15:27:15 PST 2015 - Build date
SU2-12 - Build number
21.44.8 - OTA - 2014.12.16
21.44.8.quark_verizon.verizon.en.US - System version
MDM9625_104344.184.02.71.04R, QUARK_CUST - Baseband version
3.10.40-perf-ged02eee
Thu Nov 20 23:22:43 PST 2014 - Kernel version
Thu Nov 20 23:16:37 PST 2014 - Build date
KDF21.196-8 - Build number
21.21.15 - OTA - 2014.10.30
21.21.15.quark_verizon.verizon.en.US - System version
MDM9625_104037.10.02.47.01R, QUARK_CUST - Baseband version
3.10.40-perf-g2df68ea-00001-g49a9c7a
Tue Oct 7 18:04:51 PDT 2014 - Kernel version
Tue Oct 7 17:50:06 PDT 2014 - Build date
KDF21.128-15 - Build number
21.21.12 - Initial Release
21.21.12.quark_verizon.verizon.en.US - System version
MDM9625_104037.10.02.47R, QUARK_CUST - Baseband version
3.10.40-perf-g8b90c23
Wed Sep 24 16:24:20 PDT 2014 - Kernel version
Web Sep 24 16:17:46 PDT 2014 - Build date
KDF21.128-12 - Build number
... Thom
It is definitely getting Lollipop but Motorola and Verizon have not committed to timing or features yet.
I spent a long time on hold with Verizon and Motorola today ...
The purpose of the 21.21.15 upgrade was for ...
IMS registration improvement
VoLTE (Voice over LTE) activation
It was intended to be the "released version" of the system on the Droid Turbo.
... Thom
... Thom
I don't think I have VoLTE but my phone has 21.21.15
She told me the change in the Turbo was for that purpose.
Looking at the Verizon website it does not list the Turbo as a supported HD device (yet).
There was a lag when they turned the Maxx on to VoLTE ... perhaps that is being repeated with the Turbo.
... Thom
... Thom
Yep.. I called when I notice no voice and data at the same time.. They said I needed Advanced 1.0 which give VoLTE, then after getting off the call I got a text saying they will push an update later, so I assume the 21.21.15 is part way there but not complete
Saw on a comment on another Android website that another minor update is rolling out to the Turbo that improves camera response and battery. Anyone confirm? I don't have one
Droid Turbo – Wipe Cache Partition​
Wipe Cache Partition will remove any temporary files that may be causing the problem, but will not delete your files or settings.
Lollipop
1. Ensure the device is powered off and unplugged.
2. Press and hold the Volume Down button and Power button (located on the right edge of the device) for approximately 3 seconds then release.
3. From the "Boot Mode Selection Menu" screen, select Recovery.
(Use Volume Down button to scroll through the menu options and Volume Up button to select.)
4. From the "No Command" screen (Android figure lying on his back), press and hold the Power button then press and release the Volume Up button to display the menu options.
5. Select wipe cache partition.
(Use Volume buttons to highlight and Power button to select.)
(Allow at least 7 to 10 minutes for the process to complete.)
6. When complete Reboot system now will be highlighted, press Power button to select it.
Kit Kat
1. With the phone powered off press the Volume Down and Power buttons.
2. The device will display screen with an arrow at the top pointing at the Power button..
3. Use the Volume Down and Volume Up buttons to select Recovery mode and Power button to select.
4. The device will display the Motorola logo and then the Android in distress (logo with Exclamation mark)
5. Press and hold Volume Up button for 10-15 seconds. While still holding the Volume Up button tap and release the Power button.
6. The device will display additional menu options (Text will appear in blue).
7. Use Volume Down button to scroll to wipe cache partitionand the Power button to select this option
8. The device will then perform the partition wipe (It will run for over at least 7 to 10 minutes and you need to just let it run to completion.)
9. The device will reboot and start the normal power up sequence
... Thom
Droid Turbo – Factory Data Reset​
Factory Data Reset is a tool used to remove everything that was imported, added or installed on the device. Keep in mind, when using this feature everything is deleted.
Lollipop - reset when powered on ...
TBD
Lollipop - reset when powered off ...
5. Select wipe data/factory reset.
Kit Kat - reset when powered on ...
1. Go to Settings | Backup & reset
2. Select Factory Data Reset
3. Select Reset Phone
Kit Kat - reset when powered off ...
7. Use Volume Down button to highlight wipe data/factory reset and Power button to select option.
... Thom
Safe Mode will disable all apps that you added without uninstalling them. This can help zero in on unexplained problems.
To put the Turbo into Safe Mode ...
With the power on ... press the Power key.
When the dialog appears long press on Power off
When the dialog appears press OK
It will reboot into Safe Mode
To return to normal ... reboot (power off/power on).
... Thom
With the poser on
Press the Power key.
... Thom
@ralphlexie098 had his phone attacked by his dog destroying the screen. He wanted to send it in for replacement but had ho way to do a Factory Data Reset with the destroyed screen. He used Android Device Manager to remotely request the Factory Data Reset and it solved his problem.
Before you can use Android Device Manager, you have to enable it on your Droid Turbo and associate your Droid Turbo with your Google account. I recommend that you do this as your first project after associating your Google account with your Droid Turbo.
To turn on Android Device Manager on your Droid Turbo ...
  • Open the App drawer and select Google Settings
  • Select Security
  • Under Android Device Manager ...
    • Check Remotely locate this device
    • Check Allow remote lock and erase
... Thom
With 21.44.8 installed ... go to ... Settings | Advanced Calling to turned it on. This will allow you to use data while making a call (among other things).
... Thom
System version 21.44.12 added to ... Message 1 here ... also see ... Release Notes at Motorola.
It is interesting that the build occurred on 2015.02.06 and it was released on 2015.03.06.
... Thom
That's funny - I just looked at moto's site to see if they had posted this a few hours ago and it still wasn't there.
Motorola always has more detailed changelogs than verizon but they always seem to lag a few weeks, as you noted.
Droid Turbo - Safe Mode​
You can enter Safe Mode when powered on or powered off.
When powered on ...
Press Power button.
When Power Off dialog appears ... long tap dialog
When Reboot to safe mode dialog appears ... tap OK
When powered off ...
Press Power button for a few seconds.
When phone vibrates press and hold Volume Down
When Safe Mode appears on the lower left corner of the screen release the Volume Down button.
... Thom
