Droid Ultra - Randomly Opening Music Player
dsmartin
My highly touted Ultra has an annoying habit of randomly opening and playing music files. Tried: Power cycling device, installing ATK, uninstalling DoubleTwist and going back to native player.
I routinely hit the power button to bring up lock screen when I'm done with whatever. No help.
Any suggestions would be appreciated! If nothing else works, I'll do a factory reset.
Also... maybe check the Assist function. Driving. Make sure the "Resume Music Play" is unchecked.
And for the love of God, uninstall ATK :)
Hit Power button. When menu appears long press on Power off then hit OK.
You return to normal by doing a normal reboot.
If the problem stops while in Safe Mode then it is caused by an app that you (she) added.
... Thom
