Help Droid update question
KOdroid
I have a droid razr and it keeps trying to update 98.72.165.en.us
I am concerned about screwing up my phone. Do I need this update? I think I read something about it is for roaming in canada/alaska.
Do I need to d/l it? Is there a way to disable it? Is there any advantage/detriment to downloading/not downloading?
Will it erase any pix or texts or open browser pages if I do it
Thanks
info I found
January, 2014
INTRODUCTION
We are rolling out a new software update for Verizon users with RAZR / RAZR MAXX by Motorola. With this upgrade we have fixed a few bugs reported for this device. For more information on Motorola updates and repairs, visit us at motorola.com/mydroidrazr.
NOTE: You cannot downgrade to a previous software version after installing this update.
ENHANCEMENTS
This software update is for all Verizon users with RAZR / RAZR MAXX by Motorola. After installing the software update you will notice some bug fixes, including:
Canada Roaming bug fix Fixed a bug that could cause data connectivity issues while roaming in Canada on Telus GSM and UMTS networks. Bug Fix for extended networks Fixed a bug that could cause a data roaming warning to appear while connecting to extended networks (e.g. Alaska).
I haven't received a prompt for it yet.
https://motorola-global-portal.custhelp.com/app/answers/prod_answer_detail/a_id/97886/p/30,6720,8112
No noticeable change in how the phone operates. It did not change or delete any apps, pictures, data, etc.
My phone is 2 years old and is still suffering from the same lags and slow response that many of the older phones are experiencing.
This has to be the most unexciting update for someone who lives in the lower 48. Too bad they couldn't just throw in some easter egg for us! :)
I thought my phone was defective but I guess other RAZR MAXX owners are having the same issues. I just received the update a few days ago and I was hoping it was going to resolve the lag and slow response. Looks like the only thing to do is get a new phone when I can afford it. Don't want to lose my unlimited plan from Verizon Wireless.
Does anyone know if this update addresses a problem with a feature called "fast dormancy"? This is a way to shorten any data transfer between a phone and cell and thereby reduce battery consumption. The Canadian wireless provider who is known to have this problem is Rogers. I've also experienced it using the Bahamian telephone net.
Basically what happens is the data (not voice) connection gets slower and slower and then fails outright. The work-around to date is to edit a file called build.prop. The phone must be rooted and there's an app to edit build.prop. The changes needed are way outside the scope of this area (e.g., should be in the Rooted area).
