Sorry for the jumbled title ... I haven't found a way to concisely state this problem. I also did some searching but came up with nothing.
Droid setup:
Background:
At my work, I leave my Droid in the cradle and stream Pandora for most of the day. At work, my signal rests around -93db most of the time and occasionally bounces from 3G to 1x seemingly randomly. I've noticed that I need a signal strength of -93 to stream reliably, one or two db less and I can't stream at all.
Problem:
Unfortunately, I've been having an issue where the the phone gets very hot during streaming and then the stream cuts off. The cpu temp (as reported by tempmonitor) shows as 55 C. The back (up top) is extremely hot as well.
Troubleshooting:
Theory:
I suspect that the issue has to do with the phone delivering more power to the antenna in order to pull down a proper signal ... but I can't believe it's getting this hot. Touching the back of the phone almost leads to being burned. Is there an app to monitor this? AFAIK the antenna module doesn't have a temperature sensor to tap into.
I'm still trying to track down the issue and was hoping if more people are having the issue we can work together to figure it out. If you have a theory, I'd love to try and test some out.
Thanks!
~mode
Droid setup:
- CyanogenMod 5.0.5.7
- P3Droid's overclocking kernel @ 1 GHZ (don't stop here, I'm pretty sure it's not a problem with overclocking).
Background:
Problem:
Troubleshooting:
- While I'm in my car, I can stream pandora as long as I want without issue. The temperature very rarely exceeds 42 C. Under a heavy load (without using the data), my phone never exceeds 45 C.
- Additionally, I have experienced this issue while not rooted (in 2.1) as well, I just never had any other method to monitor to the temperature other than touching the back of the phone.
Theory:
Thanks!
~mode
