Droid Wall - blocking everything
94SupraTT
Member
Has anyone had any issues with it blocking everything. I've had it set to allow certain apps though. For some odd reason it has stopped working. The only way to get any wifi app to work is through disabling it. Help :confused:
DRoidWall is basically a firewall. In a nut shell, you can block apps from accessing your wifi or mobile data (for limiting things like warez or non-internet based apps from using your data or getting advertisements) Eh, at least thats what is possible.
this has happened to me randomly but only on first install it blocks everything, then I have to white list things. Confirm your white lists, you can always unlist it, then white list it again.
as with any issues, reboot helps things.
