My Droid A855 - I let the battery run down all the way (accidentally - I usually charge EVERY NIGHT - but failed to this one night).
It would not turn on unless I put a wall charger on it, then within a minute (I could play with phone apps, etc for 1-2 minutes), sometimes before the booting process would finish, the phone would shut off. Tried two different chargers.
When it would run for a minute or two before shutting down, it would show 5% battery life, even though I've had it plugged in for hours (charge light showing).
I tried battery reboot (pull battery out, wait, put back in), plugging into wall, into laptop, etc, etc, etc.
Once when powering on, the boot screen showed up, then it shut right back off. That only happened once.
The phone was disfunctional for the whole weekend.
Then Monday, I took it into Verizon, told them everything. They put it on a charger. It booted up. I was waiting for it to shut off in a minute. The charge raised from 5% to 20%. It started taking a charge. It was at 80% once we came back from lunch.
So I wonder if when the battery is ran all the way down, it takes a very quality charger to get it charged again from that low point ???
Hope this helps anyone who experiences this problem. I'll post if I have more problems, but so far, it looks like it functions normal again.
Buffbuh
South Jordan, UT
