Help droid x 2.2 task killer
jacko1
is there a task killer that actually works on closing some apps ever since 2.2
non really works thanks in advance
On my original Droid I have found (after trying just about every task manager available) that Android does a good enough job on it's own. On the Droid X, with much more available memory that it's older sibling, I would imagine it would be even less of an issue. Advanced Task Killer did seem to do a good job but again, I had less problems using no task killer.
im looking to save battery power.since froyo it doesnt kill browser,or google maps any suggestions
its nice the only thing that bugged me with that whole text saving issue.but with 2.2 thats gone now i switch back and fourth with lp and adw cant decided and "task" issue
All our great "underground" developers will work out most of those annoying issues (as they have for the most part with the original Droid).
Why not just use the back button to get out of those apps? Pretty sure using the back button (instead of the home button) actually closes those apps down, also, google maps and the browser should not be putting hardly any drain on your battery, if they are, then theres something wrong with your phone....I never kill either of them and have great battery life.
thanks man ill keep that in mind i had an "imagio" a few phones ago still have nightmares
Don't worry if apps are still on in the background. They aren't doing anything and won't affect your battery. The only thing going to affect your battery is if you have like a streaming music program open in the background or your facebook open and set to update every 30 minutes. Only programs that are actually doing something or set to do something will use any battery. If they're just sitting there not doing anything they are affecting anything.
