Root Droid X ADB Issue - Ubuntu
anaphora68
Hi All -
Question. I am running into a weird issue with Ubuntu 10.0.4 and my Droid X. For some reason, I cannot get ADB to recognize the X.
Can anyone tell me if there is a config file I need to edit? I have tried everything imaginable.
And yes, I do have Win 7, but I want to be able to use Linux, it's personal preference. I have a laptop running Ubuntu that recognizes the X, is there a config file I need to copy?
Any help is appreciated...
Check if JDK is present in your system because ADB will not work without out. Also make sure you have updated the packages within your SDK.
If JDK is present in ubuntu and your packages are up-to-date place the SDK folder in your home directory so ADB will be easier access.
(username)@ubuntu:~$ android-sdk-linux_86/tools/adb devices
If the device still doesn't show up create a rules file.
sudo gedit /etc/udev/rules.d/70.android.rules
Copy and paste to the file:
SUBSYSTEM=="usb", SYSFS{idVendor}=="22b8", MODE="0666"
Save and exit
Unplug your phone and plug it back it and search for adb devices again and hopefully your device shows up.
Is it possible to make this thread a sticky or put along with all the other little howto's/guides? This was helpful for me, not sure if anyone else was helped by it.
