Check and see what battery setting you are on, if you are on the "Performance mode" setting then it will drain the battery greatly. I have my screen set at 45% on brightness with a widget from the Beatuiful widgets app that will put it back to 100% when I need it, that helps alot.
Also it depends on how strong the signal is in the area the phone is. Weaker signal = more battery consumption, stronger signal = less battery consumption to keep a connection.
oh and provide root
